Parking system: what it is and what it consists of
The parking system helps to make any maneuvers during parking more safer and more comfortable. But not every car even in the luxury class can have such a system, so drivers have to buy it separately. Such devices are electronic elements that measure the distance between the machine and obstacles by means of ultrasonic waves.
To begin with, you need to decide on your desires: what exactly do you want to put, how much and, most importantly, how good the quality is.
What systems are there: the features of each
Parktronics. Usually they are put, at least, 2 pieces, and further - as opportunities allow. In addition to the sensors themselves, the standard also includes an indicator and an electronic unit.
Depending on the selected shape, special installation rings may be required that compensate for the angle of inclination. This is a very important point of correct installation, as the parking sensor should look straight and not be located above 50 cm above the road level.
Rear View Camera. It is important here not only to correctly choose the camera itself, but also to buy a quality display. During the reverse motion, the screen will show everything that is happening in the "blind" zone.
Parktronics and camera. This option is more reliable. Typically, the system includes 4 sensors and 1 camera - the configuration varies depending on the manufacturer and model. Such designs must be carefully chosen, because often the quality of one of the devices.
Parking tapes — most budgetary models. Inside the bumper is mounted a special tape, which has increased sensitivity. The detection zone is quite large, but its drawback is that it does not notice the plastic obstacles. This option is less common among drivers, because it can not guarantee the same high efficiency as other designs.
What to look for when choosing
Of course, when choosing a suitable design, you need to pay attention not only to its type, but also to a number of other important features. So, you need to consider how the parking system will turn on. For example, the rear parking sensors automatically turn on during reverse driving.
Before buying it is important to determine how you are more comfortable receiving a signal about the obstacle: through video, display, sound. Usually, they choose to display the picture on the display, but in order to save some, a normal audio signal will suffice. Take into account the peculiarities of your climate. For example, some models may not work during snow or strong heating.
In the online store 130.com.ua you can find the right model for your needs and possibilities. Looking for Parking System? You can buy in Kiev, Odessa, Kharkov on 130.com.ua. Delivery in Ukraine.
See the video reviews of parking systems
Related materials:
Parktronics: Best Sellers
