Inverter generators-need or waste of money?
Inverter devices are special devices that transform alternating (220V) into direct (12V) current, and, after smoothing its pulsations with capacitive filters, reverse the current with the necessary quantitative loads. The fuel system of the device can be on diesel, gasoline or gas. Using such a device, you can get the output power with high voltage and current.
Inverters are generators of a periodic type, which very often has the shape of a regular sine wave. In theory, they can be used to obtain the current of the desired power, despite the quantitative indicators of the input voltage. The presence of 12V voltage on a permanent basis can provide the batteries that come with the device.
Purpose of Inverter Generators
One of the main ways to operate an inverter is to use it as an energy source for the operation of appliances and equipment for domestic use. It can be both an emergency and a backup device that supplies electricity to equipment that consumes 220V alternating current.
- The power of an inverter generator allows you to get energy to use household appliances for several hours.
- Inverters are also used to connect electrical appliances-planer, drill, power saws, during repair or construction, if there is no mains supply.
- In addition, very often such stations are popular among professional fans of fishing or hunting.
Inverter generators are used as a periodic substitute voltage, in cases of sudden power outages or lack of power from the network. By purchasing such a device, it can be used for quite a long time, since they are distinguished by the presence of reliable mechanisms:
1. special incendiary system, which guarantees a quick start of the generator;
2. economical fuel consumption due to the automatic adjustment system, it can be used to control the unit.
Varieties of inverter stations
There are two types of inverter devices, differing in the form of output power, differing also in price. These are devices having voltage with a pure sine wave and units with a simplified output signal, or a trapezoidal sine. These devices have some distinctive features that make each model very popular and popular.
The features of the options with pure sinusoidal power include:
1. the presence of the minimum distortion of the output voltage waves;
2. the possibility of faster operation of the inductors that make up the mechanisms of many household appliances. This ensures less heating of these devices;
3. providing less noise during operation of connected devices-hair dryers, sound amplifiers, fax machines, other equipment;
4. reduced chance that the PC can freeze;
5. reliable and long-term operation of equipment that can work poorly with a generator having a voltage with modified sinusoidal voltage.
These appliances include laptops, miscellaneous office equipment, microprocessor controlled devices, daylight devices, sewing machines or electric tools with variable speed motors, chargers.
Inverters with a modified sinusoid is better to use on modern electrical devices. Therefore, if you need to get power for a TV, refrigerator or other equipment, it is better to buy these generators. But for interaction with more “sensitive” equipment, inverter stations with pure sinusoidal voltage are selected.
Modes of operation of inverter power plants
- Long-runs for a certain period of time at rated power.
- Overload-the ability to operate power at a limit that is significantly higher than the nominal. The operation of the generator in such conditions is possible for no more than 30 minutes. Such overloads occur when, for example, the cooling unit is turned on.
- Start-the output of increased power is performed for a few seconds. This is necessary for a balanced start of the generator, in order to avoid strong capacitive performance.
What are the advantages of inverter power plants?
One of the main “advantages” of the unit is considered to be extensive functionality, which is reflected in the admissibility of energy conversion and high rates of rapid impact. Because of this, inverter generators are considered the best devices for obtaining additional or emergency electricity consumption.
No less important is the versatility of these power plants. They are an excellent option for use while working with welding equipment, various types of household appliances, power tools and equipment.
In addition, it is worth highlighting other, equally important advantages of inverters:
1. lightweight, compact size, mobility, thanks to this are useful portable devices for generating energy autonomously;
2. efficiency due to the accuracy of the calculation of the frequency of the engine speed with the load applied to it;
3. work without the issuance of noise is carried out thanks to the silencing elements and the body part, decorated with sound insulation;
4. a variety of models that can work with all kinds of fuel. There are generators on gasoline, gas or diesel fuel.
In addition, inverter units are reliable and durable devices that are made with superstable parts and connecting elements. Thanks to them, the generators are resistant to heavy and long-term loads, as well as resist the influence of extraneous adverse climatic conditions.
Draw conclusions
Thus, the need for such an aggregate is obvious. Therefore, choosing inverter generators you will not be mistaken, because these devices are characterized by high quality and reliability, are more resistant to various influences and universal. When buying an inverter generator, you should decide on the type of sine wave, so you can connect the necessary equipment and get sufficient efficiency of its operation for a long time.
And to make your choice right, you should familiarize yourself with the petrol inverter generators that are presented on the site. Among the huge selection of models of different brands, you can choose the best option for your needs. You can buy an inverter generator on gasoline at 130.com.ua in Khmelnytsky, Zhytomyr, Odessa with delivery all over Ukraine.
Materials on the topic
Generators: Best Sellers
