How to choose and buy marine receiver, acoustics, subwoofer and power amplifier for yacht
If you're going to buy a marine media receiver, speakers or a subwoofer for yacht — is necessary to distinguish plants operating on the open deck and is designed primarily for maximum volume levels without severe distortion, and the system installed in the cabin, where the sound quality is much more important than volume. So, first of all, it is necessary to determine the power output of the marine receiver or amplifier sound. Quality marine media receiver to yachts often have four separate channels of amplification, which are two stereo pairs — usually, it's 4 channels of 50 watts. To determine the full power amplifier sound often summarize the total peak power all four channels. If you are using to connect the two marine speakers, enabled only half the available power.
To reach a higher volume and good sound pressure set sufficiently large number of speakers of various sizes — from 13 cm to 25–30 cm subwoofer speaker 13–16 cm can be used marine media receiver amplifier, and for strengthening 16x24 cm speakers and a subwoofer already require a separate marine amplifier.
Such a number of speakers is very good is linked to a radar arch or side walls of the cockpit. To ensure proper operation of the speakers on the radar arch install special case of complex shape — extra stages, which pose their own dynamics. There should be a definite volume in the body, otherwise what would have been no power speaker system, it will not give full value. To improve the quality of sound systems in the catwalks deploy at a certain angle — so you can get additional benefits and the quality of sound and volume. Podiums are the main hull color and sleek shape, blends harmoniously with the surrounding design. However, there are suggestions to change the color of the inserts, which are often accompanied by the installation of changing the color of LED lamps or tapes.
The next step, consider the size of installation marine receiver. This is necessary if you plan to install new or replacement of full-time marine electronics. Most marine equipment installation has a standard size, which is measured in the DIN. This standard, which has a certain size — about 178 mm in width and 50 mm in height. Usually, manufacturers car and marine audio adhere to the following standards: 1 DIN, 1,5 DIN or 2 DIN. There is also a marine receiver to the size of 1,8 DIN. All standard sizes are different, especially in height. Thus, 1,5 DIN standard height is 76 mm, and standard 2 DIN — 101 mm.
In rare cases, a large number of devices and design of the panel itself does not allow to install the unit directly to the sea in the cockpit. Here comes to the aid of marine receiver remote control. Practical and stylish marine RC, ideal for the design of your boat and the marine receiver can be set in the cabin.
The next step you have to determine what functionality will be endowed with marine receiver. The preferred is the presence of USB interface, because the same media can store and listen to your entire music collection, not parting with it either on a yacht or in a car. By setting the cabin for more qualitative Marine Acoustics, EQ processor, DVD-player with ceiling monitor, several amplifiers, providing increased 5+1 channels audio, you can turn your boat in the movie theater on the water. If the unit is built in the sea supporting the DVD format, along with MP4/DivX, you should use these opportunities and bring the video signal to the monitor in the cabin. An additional option may be to connect a satellite radio.
In the internet store “130” you can choose and buy marine media receiver, marine acoustics, marine subwoofer, marine amplifier and other electronics to yacht or boad which will be suit your requirements. Good modern marine system worthy complement your boat and surprise your guests!
* This information was presented in a professional and technical level. Its English version is amateurishly translated. If you have intention to contribute with skilled translation you are very welcome. In return we can offer to arrange a place for your back link on our web site.
Materials on the topic
