Main advantages of GSM car alarms
Every car owner cares about the safety of his "iron horse", isn't he? But how to navigate in a variety of car protection systems, pick up and buy car alarms that will protect your car not only from carjacking, but also from any other outside interference or carjacking attempt by loading into the carriage? Innovative security systems of the new generation-GSM car alarms will come to the rescue.
What is a GSM alarm system for a car?
This is a device that is designed to monitor and protect movable objects, transmit an alarm signal via a cellular network to the phone of the vehicle owner (or his relatives, as well as the telephone of the security console). In other words, a car alarm with a GSM module allows you to control your car using a mobile phone, no matter where you or your car is located-the distance to monitor the status of the car’s security system is unlimited.
How does GSM car alarm work?
As a rule, GSM car alarms consist of a central unit and several security sensors connected to it, sometimes equipped with their own key fobs, that is, visually almost the same as classic car alarms. These sensors monitor the perimeter and inner space of the protected object, detecting the penetration of unauthorized persons into the vehicle’s interior.
Main advantages of automotive GSM alarm
1. The GSM car alarm system will find the owner of the car anywhere in the world and will provide with the mobile phone full information on the status and location of the protected object. Thus, even if you are on vacation or a business trip and are unable to personally verify the safety of the car, you can do it with the help of a GSM car alarm and a mobile phone.
2. The GSM unit has a rather wide range of functions that allow using it not only as a signaling device, but also as a listening device-just press a button and the transceiver will faithfully transmit everything that happens in the car.
3. Most automotive GSM alarms make it possible to track not only the location of the car using the GPS module, but also its speed, fuel level in the tank and direction of movement, as well as see and hear what is happening in the cabin.
4. Another equally important feature of automotive GSM alarm system is that it can notify the car owner about attempts to remove the wheels or load the car on a tow truck. In order to activate this option, you need to additionally install tilt/move sensors.
5. The unique capabilities of automotive GSM alarms can also include the ability to remotely start/de-activate the car engine from anywhere in the world. Also, the possibility of a classic engine start is not excluded, depending on the increase or decrease in temperature in the passenger compartment or in the case of discharge of a standard battery.
6. Car GSM alarms, as a rule, have a dynamic radio code that is protected from all known methods of intelligent hacking. And regular GSM alarms with a CAN module almost perfectly complement a standard car alarm with a GSM function and do not show themselves to the hijacker.
7. Also, most car alarm systems with a GSM module are equipped with their own battery, which, in the event of a disconnection of a native battery, informs the owner about the vehicle blackout. The GSM car alarm, even with the car power off, allows you to monitor the location of the car for several days. You can buy a car alarm with delivery in Ukraine to Kharkov, Kiev, Odessa on 130.com.ua.
The main differences between the models of automotive GSM alarms
The prices for GSM car alarms are different, and today there are “low cost” and “expensive” alarms with a GSM module. As a rule, cheaper car GSM alarms consist of a simple control unit with ordinary outputs for connecting the main security zones (supplementing the classic or simple full-time car alarm). In expensive car security GSM alarms, all the functions of a conventional car security system are included, and, as a rule, they are self-powered. High-end car GSM alarms contain a GPS receiver with the ability to receive information about the location of the car.
Also, these security systems differ in the way of informing . Among the GSM car alarms you will find those that send SMS-notifications and those that carry out an automatic redial with voice accompaniment. There are also combined security systems-dialing and sending SMS messages.
An important difference is the way of programming GSM car alarms . On this basis, GSM alarms can be divided into programmable SMS messages (a cheaper option, but now they are practically not produced) and DTMF signals (tone dialing via the voice menu). A similar division is inherent in the method of control, but in addition to this, the object can be controlled by calls. The priority, of course, is to set up and monitor DTMF signals — more easily, intuitively, reliably, and quickly.
Also, GSM car alarms can be classified by the method of power . Most car alarms with the GSM module are powered by a car battery-12 V. More advanced models use the reserves of the built-in battery if the main power supply is lost. Almost all modern GSM systems are equipped with an additional option-as soon as the main power is lost, the owner of the car is notified by SMS message or a call.
The price of automotive GSM alarms varies from several hundred to several thousand hryvnias. Installing a GSM car alarm in any case pays off-if not by direct prevention of car theft, then, at least, by preserving the calmness of the owner. A GSM alarm system for a car will save you from worrying about your car regardless of the distance you are from it-unlike the usual radio channel, a GSM alarm system for a car works almost everywhere and it is almost impossible to “drown out”.
It is also important to note that in all the characteristics of the range of classic car alarm systems there is one key point-the word “before”. When choosing a car alarm with feedback, this marketing move confuses the gullible consumers. In fact, this technical specification is far from reality. In a modern city noisy with radio signals, as well as in places where cars are crowded (parking, supermarket parking, busy streets, etc.), the range of reception and control is reduced by tens and even hundreds of times. Sometimes it comes to "ridiculous" when in direct view in the immediate vicinity of the car (even close to the receiver of the car alarm) the key fob does not work to remove or arm the car.
This is what robbers and car thieves use when the car owner sets the car to arm and departs from it, for example, to the supermarket, and when he returns, he does not find the car radio and valuables in the car. Reinforced concrete floors, together with radio noise, often simply exclude the possibility of receiving an alarm signal on the key fob in the event of a car alarm triggering.
A similar situation with “classic” car alarms and using the “remote engine start” function-the car is not so much in the underground parking, but sometimes even in direct view from the upper floors of the house simply does not start, because the signal to the receiver comes in a distorted form or does not reach at all.
Thus, a modern car GSM alarm system is the most acceptable variant of the security device in terms of reliability and range of the transceiver. To date, the prices of GSM car alarms, low tariffs of cellular operators (unlimited within the network without the need to replenish the account), when choosing between the "classic" systems and GSM outweigh the balance in the direction of the latter.
In the online store of automotive products "130" you can buy GSM car alarms of any class and price range, most of which have various functions-GPS module, CAN bus, camera connection, fuel sensor and others. We also recommend you to familiarize yourself with our author's review-“Magnum GSM car alarms: what to buy from the model range?”.
Materials on the topic
Car alarm Sheriff ZX-750PROBuy4427 ₴ -
Car alarm Sheriff ZX-1095PROBuy5075 ₴ 4156 ₴ -
Car alarm Cyclone X-1000Buy2899 ₴ -
Car alarm Cyclone X-470DBuy2849 ₴
