Directing cleanliness: what to choose and buy a car vacuum cleaner?
In winter, the issue of the cleanliness of the car becomes especially acute both snow and mud, which passengers put on shoes in the salon. And what would you like to have in the cabin was as comfortable as at home, is not it? Reliable guardian of cleanliness will be a car vacuum cleaner.
The most important advantage of a car vacuum cleaner is its size and low weight. Due to the compactness of such a device, you can carefully remove the most inaccessible corners of the car from debris and dirt. As a rule, car vacuum cleaners can be divided into working from the cigarette lighter and those that are powered by a battery.
Car vacuum cleaners that work from the cigarette lighter are ideal for spring cleaning of your car. They have a pretty decent power (in some models it reaches 180 watts), and the length of the cord is about 3 meters. Therefore, if you decide to buy a cigarette lighter car vacuum cleaner, we can guarantee that the problem of crumbs on the seat or debris in the trunk for you will no longer exist.
Battery vacuum cleaners for a car are often more compact, with less power, but they do quite well with ashes and small debris. One battery charge in such vacuum cleaners, as a rule, lasts for 15 minutes of cleaning-most often, this time is enough to clean up the cabin. Some vacuum cleaners have spare batteries or can work from the mains using an adapter. The main advantage of such a car vacuum cleaner is the absence of a cord, which is not confused when cleaning, and the presence of a battery that makes the car vacuum cleaner independent of the power source. Also, the battery vacuum cleaner has some drawbacks-after each cleaning you need to put it on recharging, and since many models need a 220 volt socket, it is almost impossible to do so in field conditions.
For a more comfortable and thorough cleaning of hard-to-reach places, we recommend choosing a car vacuum cleaner that has different brushes and nozzles included: brushes with a pile in order to collect sand and wool, a slit brush, a corrugated hose and others. At 130.com.ua you can buy car vacuum cleaner in Kharkov, Odessa, Kiev with delivery in Ukraine.
Some models, for example, the Alca 229 car vacuum cleaner, have the function of wet cleaning, the need for which very often occurs in winter, when puddles in the cabin from melted snow are simply unavoidable. Sometimes, along with a car vacuum cleaner, a special handbag comes to store it — such as the Heyner vacuum cleaner, for example.
Also, car vacuum cleaners vary in cost. As a rule, there are three categories: budget, average cost and expensive vacuum cleaners. Let's look at each of the categories in more detail.
Budget Vacuum Cleaner
If you want to buy a car vacuum cleaner at a low price, then be prepared for the fact that the kit will be only basic nozzles. As a rule, in cheap car vacuum cleaners there is no function of wet cleaning and their power is rather small. These car vacuum cleaners are very easy to operate-this vacuum cleaner is quite compact and lightweight, it is convenient to hold and move around the vehicle. It works like a regular vacuum cleaner, carefully and gently sucking up dirt and dust. When you have finished cleaning, simply clean the garbage bin. The main advantage of these vacuum cleaners for a car is, of course, their price. For example, in our assortment you can choose and buy a car vacuum cleaner in the low price category-these are the Elegant Compact 100 210, Coido 6028, Coido 6038 and Alca 221 models.
Mid-priced car vacuum cleaners
This category of vacuum cleaners is much more functional. Such car vacuum cleaners can have the function of wet cleaning, their filters are conveniently cleaned-just wash, but can only be used dry. In this category you can choose and buy car vacuum cleaners Elegant Plus 100 230, Elegant Plus 100 220, Coido 6038W. All of these car vacuum cleaners are equipped with a wet cleaning function.
Expensive Car Vacuum Cleaners
As a rule, these are compact and easy-to-use automobile vacuum cleaners that allow you to quickly and efficiently clean the cabin and trunk of a car on the road. The nozzle and extension cord, with which you can clean the most inaccessible places, are included in the kit of such a vacuum cleaner. The length of the cord of an expensive car vacuum cleaner allows you to easily remove the trunk. If you want to buy a car vacuum cleaner in this price category, then we advise you to pay attention to such models as the Alca 229 with the function of wet cleaning , compact Heyner CockPitBull 234,000, Alca 208 complete with a compressor, twin-engine Cyclonic Power 240,000, Alca 210 with a built-in battery and a wet-cleaning function, Dual Power 238,000 with a large number of different attachments.
Car vacuum cleaner can be presented as a gift to a car enthusiast for any holiday. Thanks to this device, the driver will no longer have to wrestle with how carefully, but at the same time, carefully clean the seats or rugs.
Today, the price of a car vacuum cleaner allows you to buy it absolutely any car owner. In addition, this is not such an expensive price for cleanliness and order, and your caring for and caring care will surely pay off for long years of service, attractive appearance and comfortable rides.
Materials on the topic
Car vacuum cleaners: Best Sellers
