Close
Processor Receivers: Pros and Cons
All receivers can be divided into 4 groups, which differ in price and functionality. The cheapest — primitive radio with mechanical switches. Slightly better will be entry-level devices with the ability to digitally adjust.
The average level includes four-channel radio with electronic control. Devices with a processor are an advanced type of models, which we will consider in this article.
Processor Receiver
Why do I need a sound processor?
The car dealership is not the best place to listen to music. The sound depends on the arrangement of the speakers: if it is asymmetrical, then you can forget about the high quality. In this case, there is an imbalance between the far and near sound sources.
To solve this problem, you need a sound processor. Such a small design independently and evenly distributes sound throughout the salon.
Sound Processor
The sound processor can be an independent device or an integral part of the car radio. There are even amplifiers with a built-in processor.
External sound processor is a powerful device that has a crossover for each channel. Sometimes they are additionally equipped with equalizers. In the end, you get a quality sound with minimal waste.
You can connect such mechanisms to any model of the car radio, even if there is no special output for the amplifier. And the installation process is also very simple, for example, you can install the structure under the seat and connect it with 1 wire.
Features of the processor
Car radio with built-in processor provide the same high quality of sound as external sound processors.
Some receivers have only some functions of the processor, so before buying, pay attention to what the manufacturer offers you. The presence of the processor implies: a digital crossover, an equalizer, a six-channel time correction. Buy a car receiver in Odessa, Kharkov, Kiev, as well as with delivery to Ukraine, you can on 130.com.ua.
Avmomagnetols
It is these functions that allow you to shift the sound or concentrate it at one point. So, you will not feel a louder sound, for example, a nearer column.
Do not forget that the sound quality depends on all the devices that are present in the sound stage. The processor is just a way to adjust the sound.
Disadvantages — the high cost of such car receivers and a rather complex adjustment. Note that processor models require the correct placement of the acoustics. If you do not have the necessary skills, it's better to contact specialists immediately.
Recommended
Related materials:
Car stereos: Best Sellers
