Wi-Fi car refrigerators: features of choice and review of the best models
If you spend a lot of time in the car, then you need to take care to create the most comfortable conditions. Auto-refrigerators is an indispensable thing for long and short trips: a bottle of cold water in the heat will be most welcome, and hot soup in the winter will warm you even in severe frost.
Among the wide range of such products stand out models with Wi-Fi: you can remotely adjust the temperature mode. One of the best manufacturers of such devices is Dometic. These are high-performance containers designed to meet your needs. Compatible with all network or onboard power supplies.
Dometic Refrigerators : go to meet any adventure. A feature of the brand’s products is the development and successful use of absorption cooling technology. Today, the company represents one of the best and innovative high quality products for cars of any brand. Consider the advantages and features of the model range with Wi-Fi.
Dometic WAECO CoolFreeze CFX 95DZ2 Fridge
It is a compressor design with two containers. Designed for cooling or freezing. Among the main features are:
- Control the temperature remotely using Wi-Fi.
- A display for comfortable device control.
- Interior lights: you can use the design even when the lights are on.
- Protection system to prevent the battery from completely discharging.
The model belongs to the A + energy efficiency class. It works in the temperature range from +10 to -22 degrees.
Dometic WAECO CoolFreeze CFX 65DZ Fridge
A powerful and high-quality refrigerator for long journeys, equipped with unique CFX electronics and the ability to store food in two temperature zones. Distinguished by good functionality:
- Interior lighting with energy saving options.
- Easy to carry: you can take with you on any travel.
- Provides a robust and reliable control mechanism.
- Equipped with USB and Wi-Fi.
The device is designed to cool and freeze products. It is characterized by quiet operation, the ability to withstand heavy loads. A similar model of the company is CoolFreeze CFX 65: two containers with a total volume of 60 liters., The surface is equipped with anti-slip properties, the total energy consumption is 58 W.
Dometic WAECO CoolFreeze CFX 50 Fridge
Design with a new, modern design with the ability to control temperature using Wi-Fi. It is used for cooling products and their strong freezing (up to -22 degrees). The display shows the main parameters of the device. The body is made using anti-slip properties to improve the safety of the body when traveling on bad roads.
The total volume of the two chambers is 46 liters, with a weight of 20.4 kg.
Dometic WAECO CoolFreeze CFX 40 Fridge
The device consists of two powerful containers for cooling and freezing food. Key features:
- The total volume is 38 l.
- Wi-Fi for temperature control.
- Possibility of deep freezing: maximum temperature of -22 degrees.
- Despite its power, it weighs only 18.5 kg.
Made from high-quality and durable materials, adapted to harsh environments.
Dometic WAECO CoolFreeze CFX 35 Fridge
Compressor design with a new design and the ability to change the temperature with a smartphone using Wi-Fi. The main features of the model:
- Indoor LED lighting with energy-saving options.
- Easy carrying: removable handles.
- Reliable case made of high-quality and durable materials.
- USB port for connecting external devices.
The average power consumption is 43 W, the volume of two chambers is 32 l.
Dometic WAECO CoolFreeze CFX 28 auto-refrigerator
Another equally powerful representative of the Dometic autorefrigerator series. Equipped with special electronics, in general, has energy-efficient properties and has a low noise level during operation.
Separate containers are provided in the refrigerated compartment with internal illumination for convenient storage of fruits and vegetables. The maximum temperature for freezing is -22 degrees.
Dometic WAECO CoolFreeze CFX 100W Fridge
This is a powerful design that is ideal for long journeys, because its volume is 88 liters. Moreover, you can control the temperature remotely: using a smartphone and Wi-Fi. Despite its power, it works quietly, without distracting you from the road or important things.
Wi-Fi auto-refrigerators are an opportunity to comfortably store and transport food, thus having hand always fresh dishes. Dometic products are characterized by high manufacturability and reliability.
You can buy a Dometic auto-refrigerator in Kharkov, Odessa, Kiev with delivery in Ukraine at 130.com.ua.
Materials on the topic
Car Refrigerators: Best Sellers
