Choosing a snow chain for your car’s wheels
Not every road in the teeth of your car. Special winter tires and even spikes on them cannot guarantee the passage of your iron horse through ice and deep snow. To increase the passable ability of your vehicle will be able to special winter snow chains on the wheels. There is a version that they came up with in the early twentieth century. A group of skiers hit the snow captivity on the rise in the Alps. The chains that they wound on the wheels helped them to get out. Much time has passed and technology has changed, but the essence has not changed.
The main purpose of chains is to improve the adhesion of the wheels of a car to the road, whatever it is covered with: snow, ice or mud. Chains on the wheels of cars differ from each other in the material from which they are made, the size of the links and design. Their purpose varies depending on the size of the link and the material. For ice, a chain with small links is suitable, and for mud and deep snow-with large ones.
Watch the video:
The material from which the snow chains are made is quite different: from plastic and special rubber to steel and aluminum alloys.
Plastic chains do not spoil tires, but quickly break, in other respects, like aluminum, and are only suitable for driving on loose snow.
Steel chains are not recommended for use on a solid surface, as they badly damage wheel rubber.
When using chains for wheels, limit your travel speed to 40–50 km/h.
Chains of rubber anti-skid are similar to harnesses or, more correctly, bandages. In this case, the speed is limited to 90 km/h, it is also possible to use them on a hard surface, while the tire is not deformed.
Advice to motorists. Usually chains are sold in pairs. If your car has one driving axle, then install the chain on it. And if all-wheel drive cars-then on all four wheels, in extreme cases-on the front axle.
Snow chains on wheels vary according to the type of weaving: stairs, Christmas tree, diamond and honeycomb. In addition, the more complex the drawing, the better the vehicle’s permeability.
The choice of chains should depend on the size of the wheel and the width of the tread, it is also necessary to take into account the type of off-road, with which they need to cope. Buy chains on the wheels can be both domestic and foreign production. Note that plastic sheathing and locks of foreign-made chains often show themselves not with the best hand. And domestic copies do not differ in functional packaging.
Advice to motorists. It is convenient to store chains on wheels in the trunk of a car in a small plastic bucket.
How to wear chains on a wheel?-you ask. The most common option is this.
- It is necessary to spread the chain in front of the wheels strictly along the axis of movement.
- Driving the wheels on a quarter of a chain.
- We throw a large part of the anti-skid chain on the wheel and fasten the lock from the inside, after we fasten the external lock, while straightening all the links.
- Tighten the chain through the tension rings in accordance with the instructions and fasten all the necessary locks and carbines.
- Drive 10-15 meters and you should tighten the chains again.
Particular attention should be paid to the locks, not every design is reliable and at the same time convenient in the process of fastening. There are also chains with a self-retracting mechanism, which during movement itself pulls it up. buy snow chains in Odessa, Kharkov and Kiev at 130.com.ua with delivery in Ukraine.
Advice to motorists. To protect the chains from corrosion, after use they should be thoroughly cleaned, pay special attention to locks. After you need to dry the chain and, if necessary, process a protective spray.
As can be seen from the above written, choosing winter chains is not an easy task. Therefore, if you decide to buy chains for wheels at low prices, specialists 130.com.ua will help you choose the best option for you.
Materials on the topic
Snow Chains: Best Sellers
