Recommendations for choosing a car radio
The radio allows you to go on long trips with your favorite music. Almost all cars are equipped with this device, so the range for it is becoming wider and wider. Drivers have many questions about the correct choice of car radio.
Some models of cars, mostly luxury, have a regular design. However, it often cannot boast of high power and good frequencies. You can buy an autoradio tape recorder in Kharkov, Kiev, Odessa with delivery in Ukraine at 130.com.ua.
What to look for?
First you need to decide on the size of the case. There are two standard options:
1 DIN is the standard version, does not imply the presence of a display, is used only for audio playback.
2 DIN-used in more modern cars, implies the presence of a widescreen display, with which you can play videos and watch pictures.
In addition to standard devices, you can pick up and car sizes of 1.5 DIN. Size is just a matter of comfort and installation possibilities. Now even compact designs can boast of powerful functionality, the presence of the necessary connectors, the ability to connect displays.
Now let's look at the technical specifications:
- Output power: the higher the rate, the better you can "swing" the system. Pay attention to the nominal rate, and not to the maximum. It is not worth much to dwell on this parameter, because it can be easily improved with the help of an additional amplifier.
- Noises. The signal to noise ratio should be between 90 dB. Be aware that the higher the score, the cleaner the sound will be.
- Tuner sensitivity is up to 1 µV. Especially pay attention to this option if you often go to places with a low signal level.
- Number of channels: can be two- and four-channel. The first option implies the ability to connect two speakers, the second-four. If this is a five-channel model, then you can additionally also connect a subwoofer. If you are a lover of high-quality and clear sound, it is better to choose a device with a large number of channels right away to expand the system.
- Equalizer and slices. Such elements allow you to balance the sound level. The more bands there are supported by the receiver, the more accurately you can adjust the sound.
- Usability: setting the backlight, design, the presence of a USB port or memory card.
Current models of radio can communicate with the phone. So, you can control the music, adjust the volume, play tunes from your smartphone. Support for regular steering buttons will allow you to switch music or adjust the volume without interruption from the road.
Buy car stereo is a practical solution for those who appreciate the comfort of travel and do not want to part with their favorite tunes.
Materials on the topic:
Car stereos: Best Sellers
