Autosignal with the autostart of the middle price segment
Cost * - from 3000 UAH.
If you have a budget of 3000 UAH, then it is worth paying attention to the Sheriff brand system. These alarms have proven themselves from all sides, namely the model ZX-1095PRO, which absorbed the best achievements and developments in the field of security systems.
The Sheriff ZX-1095PRO alarm system is designed for maximum car protection and convenience for the user. Naturally, it has all the functions that were listed above for daVINCI alarms. The first and most important thing that is changed in this Sheriff model in comparison with Sheriff models of previous generations and daVINCI (except PHI-350 Dialog) is the use of the dialogue code between the block and the keyfobs. This protects the system from electronic or intellectual methods of hacking. Plus, the keychain and the unit do not operate at the standard frequency of 433 MHz, but at 868 MHz - this provides better noise immunity of the channel and complicates the use of ready-made code grabbers, most of which are designed for a single frequency of 433 MHz. It is because of the dialogue code and work at 868 MHz that you should not spare money and buy a car alarm that will reliably protect the car from breaking.
Car alarm Sheriff has quite effective security functions. Along with the traditional relays that are used to block the engine, the Sheriff ZX-1095PRO can use a digital lock relay (it is included). This relay is interesting in that if an attacker has reached the alarm unit, it will not be possible to neutralize it by simply interconnecting the wires at the connector of the unit or by replacing the unit. This relay is controlled by a digital signal via a special separate wire from the signaling unit. The alarm unit and this relay are interconnected. Each unit works only with its own relay and this relay only works with its own unit.
In the car alarm Sheriff ZX-1095PRO, there is the possibility of using a number of additional functions, which increase the effectiveness of protection. The ability of the system to work with a so-called active label or transponder. With this tag (purchased separately), the system acquires the function of an active immobilizer. If the system is disarmed, the car is wound up and starts moving without this mark, then in a few minutes the engine will be blocked and the alarm mode is activated (of course, it is desirable to carry the tag not on keys, but separately).
Watch video reviews of car alarms
The system allows you to organize auto start of the engine - in the cold winter the car can be heated, and in the summer it can cool. The autostart function is doubly relevant in cars with a diesel engine. There are several options for autostarting the engine: from the keyfob (forcibly), a cyclic autostart (every 2-3-4 hours the engine starts for 10 minutes and then the machine goes off), starting the engine by the temperature sensor, starting the engine by voltage on the battery. A distinctive feature of this alarm is that it can use the smart block of the regular immobilizer bypass, in which it is not necessary to hide the key in order to remotely start the engine. This module is connected to the CAN bus of the car.
This system can control the module for fine-tuning of glasses, remote opening of the trunk. For security purposes, you can implement the function of the two-step opening of doors - the first pressing only the driver's door open button on the second - passenger.
The liquid crystal keychain of the Sheriff ZX-1095PRO alarm system has a sturdy body made of high-quality plastic of sufficient thickness. The metal tab for fastening the keys is Part of the keyfob housing, which makes it reliable in operation. The keyfob has a fairly large display with fluorescent backlighting and many different additional functions: there are clocks, an alarm clock, a timer, you can watch and check the voltage of the on-board network and the temperature in the car. There is also an innovation - you can choose a keyring melody in order to distinguish the melody of your key fob in one room with other owners of such systems when receiving an alarm (tripping).
Many functions can be controlled directly from the keyfob, for example, by starting the engine by the time, using the alarm clock, you can set the different time for which the engine will start, control the turbo timer (if this function is implemented). With the help of the key fob, the system can be put in the service mode for transferring the machine to the service. The key ring has a so-called battery saving mode, so the batteries last long enough, in comparison with other security systems (about six months). At 130.com.ua you can buy car alarm with autostart in Kharkov, Odessa, Kiev with delivery to Ukraine.
Signaling sheriff is very convenient to install - all power relays are hidden in the block, the unit itself is medium in size, which makes it very convenient to place and connect, since all connectors go to one side.
This system can be recommended for installation in cars of the middle class, and it should be installed by qualified installers.
Cost on 130.com.ua
Related materials
Car alarm Sheriff ZX-750PROBuy4427 ₴ -
Car alarm Sheriff ZX-1095PROBuy5075 ₴ 4156 ₴ -
Car alarm Cyclone X-1000Buy2899 ₴ -
Car alarm Cyclone X-470DBuy2849 ₴
