Cleaners on the battery or from the cigarette lighter: which is better
Auto vacuum cleaners save time on cleaning the car interior, because you do not need to call in the car wash every time. In addition, these designs are compact and fit in any trunk. Among the entire range of models can be identified 2 main categories: devices on the battery and cigarette lighter.
Drivers are often faced with a difficult choice between them, because each of them has its advantages and disadvantages.
Battery-powered auto-vacuum: pros and cons
Such models belong to a higher price segment. Their main advantage is that you do not depend on the length of the cord and can be cleaned even in the most difficult places. But the disadvantage of them is that one battery lasts for 30 minutes. And as the battery runs out, the power will drop.
Auto-vacuum cleaners on batteries are suitable for those who need only occasionally to clean the cabin and who are ready to constantly monitor the level of charge.
Auto-vacuum from the cigarette lighter: pros and cons
Such models have a low cost and at the same time more compact than the device on the battery. Conditionally, they are limited in duration of work as the battery also has the property to discharge. But at the same time, the duration of their work is much longer. They are more convenient to use for General cleaning and take with you on the road.
The only drawback — the cord, which can limit the range and interfere.
So which is better?
It all depends on your goals and preferences. For example, if you are used to do cleaning every morning in the cabin, it is advisable to choose a model from a cigarette lighter. After all, so do not need to worry constantly about the charge. But those who fully appreciate the comfort and removes much less, you can give preference to devices with its battery.
Auto-vacuum to buy with delivery to Ukraine in Kharkov, Kiev, Odessa can be on 130.com.ua.
We recommend:
See video reviews of auto vacuum cleaners
Car vacuum cleaners: Best Sellers
