Pure Thursday!
Car Vacuum Cleaner on Pure Thursday
The symbolic tradition to clean up every Thursday or “Pure Thursday” has its roots in the great Easter holiday. Why don't motorists take note of this useful custom. Caring for a car driver can easily cope with this task using a modern auto vacuum cleaner that can take on the “lion's share” of the entire cleaning .
Car vacuum cleaner helps you keep your car clean. Basically, a complete cleaning of the car with the help of the auto vacuum cleaner takes no more than 15-25 minutes-and your car will be clean. General cleaning, small cleaning, cleaning debris, dust, wool-with a car vacuum cleaner all this you will not be difficult. You can buy a car vacuum cleaner in Kharkov, Kiev, Odessa with delivery in Ukraine at 130.com.ua.
See a video review of car vacuum cleaners:
How to effectively apply the vacuum cleaner for a thorough cleaning in the car? To begin with, it is better to vacuum the cabin from the top down, i.e. the ceiling, then the seats and the floor. So the dust will not spread through the cabin. Next-in order.
Ceiling
Often during cleaning in the cabin about the ceiling, which accumulates a lot of dust, is forgotten. It is recommended to vacuum it at least once a month to keep the air in the cabin clean. It is recommended to clean the ceiling with a car vacuum cleaner without attachments. Additional attachments often reduce the cleaning area and with them cleaning will last a little longer, and you will not see the difference as a result.
Seats, doors
Starting with the driver, we carefully vacuum all doors. Then proceed to the seats and covers (if any), which we remove. Vacuum cleaners with a set of different nozzles and brushes will be most welcome.
They will help to remove dust, ash, animal hair, dirt from uneven relief surfaces and hard-to-reach places. For a more thorough cleaning and removal of deep dirt you will need wet cleaning with special detergents. A vacuum cleaner with the function of wet cleaning will easily remove moisture and foam from the surface after washing. In addition, such vacuum cleaners also perform dry cleaning more qualitatively due to more reliable seals, high-quality filters, and modern filtering systems that the car vacuum cleaner has with wet cleaning. You can find such models in the range of 130.com.ua.
Dirty floor mats, floor
The same function will help to collect wet dirt, melted snow, or anything spilled from the floor (or the seat) with a vacuum cleaner. But for a thorough cleaning, it is still worth taking out all the rugs, moving the seats aside and carefully vacuuming all the secluded places. Vacuuming car mats is best done using a brush head on the end, since it is to her that you can remove annoying dust and dirt from the unevenness of the carpets.
Dashboard
Do not disregard and dusty dashboard. It is better to vacuum it with a special brush, carefully collecting dust and small debris.
Trunk
Unpleasant smell, confusion and pollution-a common problem in this area. Sometimes it is enough just to clean the compartment from debris, unnecessary things, take a car vacuum cleaner and carefully vacuum the protective cover and the trunk itself. In case of heavy pollution, an effective cleaning will be ensured by a preliminary washing, and then a vacuuming with a wet cleaning. Also for cleaning in the trunk of the car is perfect car vacuum cleaner with a turbo brush.
Completely vacuuming the cabin and the main part of the general cleaning of the car according to the tradition of Maundy Thursday is over. In fact, this work can be quite burdensome, fast and efficient if you have a vacuum cleaner, which you can buy in our online store.
Minisinks on “Pure Thursday”
Maintaining cleanliness in the car is a difficult and not very pleasant thing. But we still visit the car wash and try to ensure that the car is always clean inside and out. To cope with this process, we use assistive devices.
A bucket and a rag do not inspire a chance of success, but the Minisink does its job well: it directs the flow of water under high pressure to the right place. Buying such a design is not only a reasonable solution, but also an advantageous one. After all, you save on services of car washes, and an expanded range of models allows you to choose a functional and economical mini wash.
Watch videos about high pressure washers:
So, in order to choose the right device, you first need to decide which parameters to pay attention to.
10 tips for choosing a high pressure minishew
When choosing a car wash, consider the following options:
1. Performance-depends on it the power of the water supply.
2. The maximum pressure is on average 70-150 bar. For effective cleaning of a passenger car, such parameters are quite enough.
3. The pump in the electric pump should be made of durable material. Plastic pump does not guarantee a long service life. Better to give preference to metal.
4. The filter is necessary to protect water from debris and dust. It is more practical to use reusable filters.
5. Water heating system-here you can not depend on home plumbing. In winter, this feature will be doubly useful.
6. Total Stop system-designed to save water. Blocks the flow of water after 20 minutes of using the sink.
7. Nozzles allow you to use the minisink more universally.
8. The size of the hose should be such that you can easily reach any part of the car. The optimal hose length is 5-7 m.
9. Provides for the use of detergents to improve the result.
10. Outlet water temperature.
These tips will help you choose the right minimoyu taking into account your wishes. As you can see, such devices will be extremely useful when washing cars.
Related Materials
Car vacuum cleaners: Best Sellers
