How to Choose a Car First Aid Kit: Standard or Extended?
A car first aid kit is a mandatory piece of equipment for any vehicle, but not all kits are equally useful in real-life situations. Today’s market offers both basic "Eurostandard" kits and extended sets with additional emergency supplies. Choosing the right kit depends on driving style, travel frequency, and even who’s riding with you.
What Does a Standard (Eurostandard) First Aid Kit Include?
The so-called Eurostandard first aid kit complies with TU 21.20.10-002-96520621-2016 technical specifications and includes a clearly defined minimum set:
- Sterile and non-sterile bandages
- Tourniquet for stopping bleeding
- Antiseptic wipes and dressings
- Adhesive bandage (plaster)
- Medical gloves
- Scissors
- First aid instruction manual
This kit is designed to meet road safety regulations and is suitable for providing basic pre-medical care until emergency services arrive.
What Makes an Extended First Aid Kit Different?
Extended kits include everything in the Eurostandard version plus additional items such as:
- Burn relief and cooling gels
- Anti-allergy and insect bite treatments
- Pain relievers (paracetamol, ibuprofen, etc.)
- Chlorhexidine wipes or alcohol swabs
- Thermometer, tweezers, flashlight
These kits are ideal for long-distance trips, countryside travel, family outings with children, and for drivers who want to be prepared for a wider range of situations.
City or Highway: What Needs Should You Consider?
When choosing a first aid kit, consider how you use your vehicle:
- City driving: A basic kit is often sufficient, as emergency services are usually quickly available.
- Highways and long-distance travel: An extended kit is recommended since help may take longer to arrive.
- Traveling with children: An extended kit is preferable, including allergy medications, a thermometer, and fever reducers.
If the vehicle is used for work (taxis, deliveries, travel to remote areas), a minimal kit may not be enough.
Shelf Life and Contents: What to Check Before Buying
When choosing a kit, make sure all components are within their expiration dates. Also check for:
- Intact packaging and factory seal
- Instructions in Ukrainian
- Well-organized contents — everything should be easy to access
Regularly checking your kit is not just a formality — it’s a matter of personal safety.
How to Store a First Aid Kit in Your Vehicle?
It’s best to keep the first aid kit in the cabin or in a dedicated section of the trunk for quick access in an emergency. Avoid storing it in direct sunlight or near heating elements — high temperatures can reduce the shelf life of some components.
Conclusion
A car first aid kit is not just a box to pass inspections — it’s a potentially life-saving tool in critical moments. A standard kit covers the basics and meets legal requirements. But if trips are frequent, long-distance, or with children, an extended kit is the better choice.
The car first aid kit catalog on 130.com.ua features both standard and advanced kits — with verified contents and valid shelf lives.
