4 reasons to buy a car vacuum cleaner
Many car owners are wondering: do they need to buy a car vacuum cleaner? Of course, it is necessary to clean the cabin, even if you are very careful, anyway dust and dirt will accumulate, especially in hard-to-reach places. Someone will say that cleaning can be done with a regular household vacuum cleaner. Yes, and this is true-the functions of ordinary and car vacuum cleaners perform the same. However, there are several reasons why you should prefer a specialized model, specially created to perform the cleaning in the car.
What are the advantages of buying a car vacuum cleaner?
There are 4 main reasons:
Mobility
This is probably one of the very important factors in favor of a car vacuum cleaner-you can always and everywhere take it with you, go to the cottage, beach, picnic, into the forest, etc. And immediately after the walk, clean the cabin from sand, earth and other debris. This can not be done with a regular stationary vacuum cleaner.
Autonomous power
If the home vacuum cleaner is always working from the outlet, then the car can work where there is no access to the electrical network. As a rule, most models are connected using a special adapter through the cigarette lighter directly to the vehicle’s on-board network, which has a voltage of 12 V. It is very important to look at the length of the cord, which should be sufficient for cleaning the entire cabin, if it is short, it will be inconvenient to use it .
In addition, many modern devices are equipped with built-in rechargeable batteries, which allows them to be used in any conditions, not only in the cabin of the car, but also where there is no power supply. The operating time of such units directly depends on the capacity of the battery used.
Small sizes
Compact size, on average, the length of the body is from 30 to 50 cm, you can always carry it with you. In operation, such a gadget is very simple and convenient. It can be put in the trunk, and it does not take up much space, but it will always be at hand. It is also worth saying that the nozzles of such models are also small in size, which allows you to gain access to all hard-to-reach places that a regular brush will not reach. This significantly improves the quality of cleaning.
Low weight
Most models of auto vacuum cleaners weigh very little, their weight does not exceed 1.5 kg. But stationary can weigh 3, 5, 7 and more kg. It is much more convenient to hold a small and light device in your hands, so cleaning will not cause much trouble. Even fragile girls can handle it. Just remember that the more powerful the vacuum cleaner, the harder it will be. Therefore, it is very important when buying to find the right combination. After all, apart from low weight, the device must absorb dust well, only then will it benefit.
What else is worth paying attention to when choosing a car vacuum cleaner?
In addition to the power, size, type of power and weight of the device, there are a number of important indicators that must be taken into account if you want to buy a practical vacuum cleaner that will be convenient to use.
Dust collector type
Everything is very simple: dust collectors are plastic and fabric. Plastic is more practical, as such a container can be easily washed, while the fabric requires more attention. Cloth bags are harder to clean, after washing they need to be dried.
For wet or dry cleaning
Car models, like home models, are also divided into those that are intended only for dry cleaning, and those that are also suitable for wet cleaning. The latter will be useful if in the salon someone suddenly pours water or juice. It can also be used to clean the snow from the salon floor mats. Therefore, if you need a universal unit, it is better to choose a model with the possibility of wet cleaning.
Number of nozzles
The more nozzles in the kit, the more versatile this model will be and the easier it will work with it. After all, the trim material can be different, so the driver may need a variety of brushes. For example, a turbo brush will help clean the seat of wool and lint. Special crevice nozzle is indispensable when cleaning small debris, which often accumulates between the seats and in a variety of hard-to-reach places and the usual nozzle is not removed.
As you can see, the vacuum cleaner is a very useful thing that makes life much easier, so every car owner should definitely have it. With it, you can always be kept clean in the car. You can buy a car vacuum cleaner in Kharkov, Kiev, Odessa with delivery in Ukraine at 130.com.ua.
Related materials
Car vacuum cleaners: Best Sellers
