Individual registration discounts
Close
What is engine insulation?
Engine StP HeatShield Insulation is a special material that is made from gasoline and oil resistant fabric. The main feature of such heating is that it is not a conductor of electricity.
According to the manufacturer, engine heater of this type will be useful for any car perfect.
Advantages of engine insulation:
Advantages of engine insulation StP HeatShield
  • engine warms up faster
  • reduced noise from the engine compartment
  • heat retention in the engine for 6 hours
Engine Thermal Options
Many car owners in the quality of the engine insulation use sound insulation with foil layer. It helps, but it is worth noting that this method is quite unsafe. As you know, the foil is a good conductor of electric current and when used in the space under the hood, the battery terminals or other contacts can close, which in turn can lead to the burning of sound insulation materials and, in consequence, to a car.
Engine Insulation StP HeatShield
Also, some motorists use different covers for engine insulation. This method is also unsafe! And the reason is that such fabric materials can easily absorb oils and gasoline and become a source of ignition.
As described above, the special insulation of the StP HeatShield engine made of non-woven fabric does not absorb oils and gasoline and other lubricants and is absolutely safe for use in the engine compartment. Engine insulation can be bought in Kharkov, Kiev, Odessa with delivery in Ukraine at 130.com.ua.
Comparison table of engine insulation
StP HeatShield Soundproofing with foil Fabric blankets
Engine warm-up time 5 minutes 9 minutes 10 minutes
Engine cooling time 4-5 hours 3 hours 3 hours
Fire Resistance Fireproof Possible fire Possible fire
Installation difficulty Easy installation Medium difficulty Easy installation
Output
After carrying out a small test of this engine heater, it turned out that it copes with its functions perfectly, especially with the function of noise and thermal insulation. The noise from the engine compartment has become noticeably less. The engine started running in the morning without problems, at a temperature of about -3 ° C outside. As for the preservation of heat, the engine after the shutdown was warm for more than 4 hours, which I consider to be quite a worthy result.
You can buy an engine insulator StP HeatShield at 130.com.ua.
Materials on the topic
